Free Car Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 Honda CRV 03 CRV wheel noise
Posted at Tue Nov 17, 2009 7:21 am |
By
teapartyriver55,
New to the forum |
Give Feedback | Votes: 0 |
Drive Train Axles Bearings problem
2003 Honda CRV 4 cyl All Wheel Drive Manual 140000 miles
I'm getting a humming/rubbing noise every time the tire rotates. I'm guessing it's the wheel bearings. Would anyone have directions on how to diagnose which ones and how to replace them? |
Find a
car repair manual for your Honda CRV Repair Question.
Posted at Mon Dec 21, 2009 3:49 pm |
By
Msesky,
Likes to hang around! |
(13) Give Feedback | Votes: 0 |
Okay now first thing you should do is check if your tyres are scalloped, this also creates a bearing noise, take it to your local tyre shop and get them to hav a look its ahrd to explain what this looks like. If you want to check your wheel bearings you need your vehicle to be off the ground. Start with the rears as they are the most common ones. Hold the shock coil and spin the wheel, now if you feel and hear a rumbling it will be your bearing. Do this with all wheels. You wont be able to do your front bearing as they are a pain in the exhaust. You need to press them out and unless you have all the tools you wont even be able to remove the hub. With the rear bearings its easy oif you have drum brakes. All you do is removes the wheel, remove the drum, remove the metal cap covering the bearing nut. (you can do this by putting a chisel in between the gap and hitting with a hammer do this all the way around untill it pops off.) Remove the bearing centre nut. Then it will be off. But make sure you phone honda to get a bearing torque as it is important to torque the nut up to the correct torque or you m ay have issues.and make sure you punch the nut into the groove, you should understand what i mean when you see it. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
