Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
2003 Honda Accord 4 cyl Front Wheel Drive Automatic 90,000 miles
I would like to know how to manually open my gas cover. The lever that opens it does not seem to be working and I cannot put gas in the car unless I get this open. HELP..... I am on empty and need to go to work in the morning. Is there anyone out there that knows the answer to this before I take it to the dealer?
Sometime the metal tab on the fuel doog gets bent out of shape, not allowing the door to spring open. Have someone try to manually open the door from the outside as you pull the release. If it opens, reshape the metal tab to allow the door to pop out when the cable is pulled.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
