Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Volkswagen Eurovan
Auto Repair1998 Other Volkswagen Mod...
Auto Repair1976 Other Volkswagen Mod...
Auto Repair1978 Other Volkswagen Mod...
Auto Repair1995 Nissan Pathfinder
Auto Repair2001 Other Volkswagen Mod...
Auto Repair1968 Other Volkswagen Mod...
Auto Repair2000 Honda Civic Overhea...
Auto Repair2002 Other Volkswagen Mod...
Auto Repair1970 Chevy Cheyenne Cran...
Auto Repair1997 Other Volkswagen Mod...
Auto Repair1991 Honda Accord Overhe...
Auto Repair1985 Other Volkswagen Mod...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2003 Ford Taurus Idles roughly even quits
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Apr 28, 2008 5:16 am
By trenfrow, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic 150036 miles
The check engine light came on about a week ago and the car began running rough at very low speeds and when idling. Autozone's OBD II diagnostic computer spit out O2 sensor codes. I replaced both the O2 sensors but the car runs just as poorly as before. When the RPMs are below 1000 it bucks and even quits if you sit still in traffic for more than a few seconds. Do I need to replace the rear O2 sensors or is this a Mass Air Flow sensor problem or something else? I don't want to spend more money on a guess and check fix.
Find a repair manual for your Ford Taurus Repair Question.
By Advertisment,
Posted at Mon Apr 28, 2008 11:41 am
By legitimate007, Moderator
Reputation: 133.8Reputation: 133.8Reputation: 133.8Reputation: 133.8Reputation: 133.8Reputation: 133.8Reputation: 133.8 (134) Give Feedback | Votes: 6
well I wanna say your idle air control valve by what your telling me, but here are a couple of things that you can check on your own that will put checks next to the list of possible causes. one is ignition and spark and the other is fuel pressure. I will send you a couple of video links that will show you the easy way to do these your self. hang tight.
Posted at Mon Apr 28, 2008 11:42 am
her is a link to show you an easy way to check ignition and spark.:
http://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Posted at Mon Apr 28, 2008 11:43 am
HERE IS A LINK TO SHOW YOU AN EASY WAY TO CHECK FUEL PRESSURE/l . Also remember to check for vacuum leaks first before anything else
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Posted at Mon Apr 28, 2008 12:10 pm
If it were either of those things, wouldn't I expect performance problems all the time, not just when the car is in idle?
Posted at Mon Apr 28, 2008 2:31 pm
By BMRFIXIT, Tech level 10
Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6 (311) Give Feedback | Votes: 12
not all codes related to o2 sensor means that sensor bad
if you have the p code that auto zone came out with
that p code will help to pin point the trouble area
check for a vacuum leaks and check mass air flow sensor
check egr valve (if have one )
Posted at Mon Apr 28, 2008 5:21 pm
By TaurusWheel, Tech level 5
Reputation: 85.1Reputation: 85.1Reputation: 85.1Reputation: 85.1 (85) Give Feedback | Votes: 8
If you're getting codes showing multiple o2 sensors faulting, most likely it's something other then bad o2 sensors, usually multiple failures are uncommon. Check for a vacuum leak somewhere, check the pcv hoses for pinholes, a common cause of lean codes,, as an aside, my son's 93 Taurus spit out o2 codes, indicating a lean condition, turns out the ground was corroded.
Posted at Wed May 07, 2008 6:26 am
It was a vacuum hose leak.
Thanks for the help all.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
