Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Honda Accord Car W...
Auto Repair1998 Pontiac Sunfire Pr...
Auto Repair1998 Ford Windstar Stal...
Auto Repair1991 Mazda 626 Speedometer
Auto Repair1995 Jeep Cherokee Car
Auto Repair2005 Dodge Caravan Stee...
Auto Repair2001 Jeep Grand Cherokee...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2003 Ford Ranger trouble codes
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Sep 06, 2008 8:04 pm
By moonshin, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
2003 Ford Ranger 6 cyl Two Wheel Drive Manual 135 km miles
hi guys, i am having trouble diagnosing a problem. my engine light is on. when i scan for codes it comes up with " bank 1 lean " i am having trouble figuring out what is causing this. the symptoms are: poor fuel economy, engine idle speed is usually too high or it is loping and it lacks the usual power.
any ideas?
Find a car repair manual for your Ford Ranger Repair Question.
Posted at Sun Sep 07, 2008 12:52 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3Reputation: 1006.3 (1006) Give Feedback | Votes: 75
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
* TIP: On many Fords, a P0171 and/or P0174 Lean Code may sometimes appear because of a bad Differential Pressure Sensor (DPFE). This sensor monitors EGR flow, and is located on the engine near the EGR valve. There are two hoses that connect the sensor to the tube that runs from the exhaust manifold to the EGR valve. The sensor misreads EGR flow and the computer increases EGR which has a leaning effect on the fuel mixture. The fix is to replace the DPFE sensor.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
