Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Honda Accord Oil A...
Auto Repair2002 Ford Taurus Over H...
Auto Repair1987 Cadillac Deville P...
Auto Repair2000 Dodge Caravan Hot Air
Auto Repair2000 Pontiac Grand Am D...
Auto Repair2000 Ford F350 Auto 4x4
Auto Repair2002 Ford Mustang Hard ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2003 Ford Focus Fuel Problems
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Sep 21, 2008 12:33 am
By tidus67, New to the forum
Give Feedback | Votes: 0
2003 Ford Focus
I have a 2003 Ford Focus LX, just your vary basic edition of the focus model. Awhile ago the engine went out on the car, as I later found out they do on most Focus's.
I should have junked the car right there but because of circumstances I was not able to. I had to let it sit for about 8 months until recently I was able to afford to get the engine replaced.
Now I replaced the engine and was able to drive it for about 2 days before it died again. The mechanic the replaced the engine gave a quick glance at it and said that the fuel pump needs to be replaced.
Before I give him more money to replace the fuel pump, I wanted to know what the likely hood that a clog in the fuel filter or lines could cause this problem. If so are there any tips on fixing this myself, I have thought about replacing the fuel filter myself already.
The exact problem is that it acts like its going to start up but just can't quit seem to turn over. Its getting enough spark and the battery is good. I've even reset the relay and the fuel cutoff switch and still nothing. Please help I really don't want to dump anymore money into this POS.
Find a car repair manual for your Ford Focus Repair Question.
Posted at Mon Sep 22, 2008 10:02 am
By renaudTN, Tech level 4
(18) Give Feedback | Votes: 0
If you are absolutely positive that the car has good sparks, and enough voltage to crank the starter like it supposed to, then that leaves a fuel related problem, or a compression problem.
When you turn your key ON, do you hear the fuel pump? If not your fuel pump is not getting power, and you have a problem in the circuit (relay, wires, fuse, ground etc).
If your fuel pump turns on, you need to do a fuel pressure test.
If low pressure, then you have pinpointed the problem. However, it doesn't mean that the fuel pump is the problem. You could have glogged filter, glogged inlet sock, defective fuel pressure regulator, leaky injectors, etc.
If pressure is good then that leaves you with a compression problem (do a compression test on each cylinder).
When you crank the engine, how does it crank? (normal, slow, fast). If your engine is cranking faster than normal, you have low compression. This could be a broken timing belt (replace every 120,000 on ford focus 2.0 L), or blown head gasket, or cracked cylinder head, broken camshaft, or plugged catalytic converter.
If you find out that you have low fuel pressure, and want to replace your fuel filter, here's what to know:
-Get you a haynes/chilton manual
-Wear safety glasses
-Before you start make sure there's no pressure left in your system (remove the fuel pump fuse and crank your car a few times; that should do the trick)
-Your fuel filter is right beside your fuel tank
-You can replace it without any special tool, but it's easier if you have the Ford fuel line tool.
-make sure you put the filter back with the flow in the right direction.
Again, the first thing you want to do here, is doing a fuel pressure test to make sure your problem is fuel related.
Good luck and let me know how it goes.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
