Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
2003 Ford Explorer 4 cyl All Wheel Drive Automatic 95000 miles
My ABS light came on what does that mean? Also I just added more freeon and my ac works but on the driver side it kicks out warm air and now the other side is blowing warm air but the back is still cold.
ABS light is the anti lock brake system that help you give the ability to recover ther steering should the truck go into a skid. IT grabs and releases the brakes in a pulsating fashion. There are sensors that record the wheel speed and when any are not giving the same speed to the computer it can throw the light and sometimes give a false abs braking action.
When the light is on there is no longer a functioning abs system present although your mechanical brkes will still work.
Get the codes read in the computer and post them. OR take it to a professional shop that uses a hand held computer that interfaces with the trucks for them to diagnose it properly.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
