Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Drive Train Axles Bearings problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic 85000 miles
My Explorer has leaked here and there from the rear of the vehicle for a little over a year. I had a friend of a friend who's a mechanic take a look a year or so ago and he told me it was nothing I needed to worry about right away. Well, now it's leaking a little more consistently (instead of a drop or two a week, it's a drop or two a day). Can you tell me what this is and what it might cost to repair?
there are a number of places that can leak oil, often it is the flange seal on the transmission or the diff, these are not expensive to replace seals will cost around $20. and about 1 hrs labour, but i would get it inspected first as you do need to see these things first hand to make sure that it is what is leaking.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
