Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2003 Ford Escort 4 cyl Two Wheel Drive Manual 49000 miles
I have an intermittent oil leak coming fron underneath the car, on the drivers side. I checked the oil pan, it's tight, and the valve gasket cover seems tight also...any suggestions?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
