Drive Train Axles Bearings problem
2003 Dodge Truck 6 cyl Four Wheel Drive Manual 22 miles
I installed a clutch in my 3/4 ton cummins. The clutch function is very smooth and shifts very well into the forward gears, but it won't go into reverse without alot of force or shutting engine down. The hydraulics worked fine with the old clutch. I had the flywheel ground, it measures 1.5 inches in thickness now.Is this too thin? Is there a longer rod for the slave cylinder? The clutch is back out of the truck and everything seems ok bearings ect...Old cluch slipped a little when towing. Thank you in advance
