Check your fans. They are not turning on when they are supposed to. Unplug the connector to the fans. Use jumper wires, connect the fan connectors directly to the battery. Do on both fans. If they work, your fan is good. Then check the fan relay in the relay box, next to your intake box. Try swapping a couple of relays around. You can also use the jumper wires to bypass the relay to see if the relay is at fault. If fans turn on, replace the temp sending unit.
