After getting nowhere with the dealer, who made the suggestion that Blue Planet gas was causing my mileage problem, I played a hunch that it might be caused by the injectors, and added a can of SeaFoam to the tank right before my next fill of gas. Almost immediately, my mileage went up, and within a week had increased from 10 to over 15 MPG (city). Whereas my fuel gauge needle used to plummet every time I turned on the engine, it now stays pleasantly up in the three+ quarters full range for a good part of the week. I don't know what the WB
dealership might have done to cause or exacerbate this problem, but I feel that the SeaFoam has rectified the situation, and now I don't care. I should now be able to drive to Wausau, a 180 mile trip, on less than half a tank of gas, as I could before the 30K maintenance (dis) service performed by the dealer. As a general tip for others, beside checking the O2 sensors, make sure the injectors are NOT gummed up, as you will definitely lose gas mileage. Three cheers for SeaFoam. No kudos to Dodge dealers, sorry...
