Suspension problem
2003 Chevy Venture 6 cyl Front Wheel Drive Automatic 159440 miles
i need to know how to replace wheel bearing assmbely on front axel of venture 03 with ABS senser taking them out and put back on do you hammer them back on or need toles for that...thx
Find a
repair manual for your Chevy Venture Repair Question.
Posted at Mon May 12, 2008 10:01 pm
By
Advertisment,
Find a
There should be a large 1 or 1 1/2 nut which keeps the drive spline, U-joint and wheel hub together. You need to remove the calipers, brake shoes, shield and rotor then you can access the hub. Remove the nut and the hub should come off the splined U-joint.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
