SELF-DIAGNOSTICS -2003 Chevrolet Cavalier
Page 1 of 3
NOTE: For circuit reference, see WIRING DIAGRAMS. For component locations, see COMPONENT LOCATIONS. For connector identification, see CONNECTOR IDENTIFICATION.
DTC P0113: INTAKE AIR TEMPERATURE SENSOR CIRCUIT - HIGH VOLTAGE
Description
The Intake Air Temperature (IAT) sensor is a variable resistor. The IAT sensor has a signal circuit and a low reference circuit. The IAT sensor measures the temperature of the air entering the engine. The Powertrain Control Module (PCM) supplies 5 volts to the IAT signal circuit and a ground for the IAT low reference circuit. When the IAT sensor is cold, the sensor resistance is high. When the air temperature increases, the sensor resistance decreases. With high sensor resistance, the PCM detects a high voltage on the IAT signal circuit. With lower sensor resistance, the PCM detects a lower voltage on the IAT signal circuit. If the PCM detects an excessively high IAT signal voltage, indicating a low temperature, DTC P0113 sets.
Conditions For Running DTC
DTCs P0117, P0118, P0125, P0502 or P0503 are not set.
The engine run time is more than 5 minutes.
The Vehicle Speed Sensor (VSS) indicates that vehicle speed is less than 15 MPH.
Conditions For Setting DTC
The IAT sensor signal voltage indicates that the intake air temperature is less than -38°F (-39°C) for 6.25 seconds.
Actions Taken When DTC Sets
The PCM illuminates the Malfunction Indicator Light (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions For Clearing MIL/DTC
The PCM turns OFF the Malfunction Indicator Light (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
http://www.ondemand5.com/mric/common/asp/printart.aspx
9/6/2008
Page 2 of 3
Clear the MIL and DTC using a scan tool.
Test Description
The number below refer to the step number on the diagnostic procedure.
6 - This step tests for the proper operation of the circuit in the low voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to voltage.
Diagnostic Procedures
1.Perform diagnostic system check - engine controls. See DIAGNOSTIC SYSTEM CHECK - ENGINE CONTROLS under SELF-DIAGNOSTIC SYSTEM. After performing diagnostic system check - engine controls, go to next step. 2.Connect scan tool. Turn ignition switch to RUN position, with engine off. Observe the IAT sensor parameter. Is the IAT sensor temperature less than -36°F (-38°C)? If yes, go to step 4. If no, go to next step. 3.Observe the Freeze Frame/Failure Records data for this DTC. Turn ignition switch to OFF position for 30 seconds. Start the engine. Operate the vehicle within the Conditions for Running the DTC. See CONDITIONS FOR RUNNING DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records. Does the DTC reset? If yes, go to next step. If no, go to DIAGNOSTIC AIDS. 4.Turn ignition switch to OFF position. Disconnect IAT sensor harness connector. Connect a Digital Multimeter (DMM) between the signal circuit of the IAT sensor and a good ground. Turn ignition switch to RUN position. Does the DMM voltage measure more than 5.2 volts? If yes, go to next step. If no, go to step 6.
NOTE: If a short to voltage occurs the Engine Coolant Temperature (ECT) sensor may be damaged.
5.Check the signal circuit for a short to voltage. Repair as necessary. Did you find and correct the condition? If yes, go to step 15. If no, go to 12. 6.Turn ignition switch to OFF position. Disconnect IAT sensor harness connector. Connect a 3-amp fused jumper wire between the signal circuit of the IAT sensor and the low reference circuit at the IAT sensor harness connector. Turn ignition switch to RUN position, engine off. Observe the IAT sensor temperature using a scan tool. Is the IAT sensor temperature more than 262°F (128°C)? If yes, go to step 10. If no, go to next step. 7.Turn ignition switch to OFF position. Connect a 3-amp fused jumper wire between the signal circuit of the IAT sensor harness connector and a known-good ground. Turn ignition switch to RUN position, engine off. Observe the IAT sensor temperature using a scan tool. Is the IAT sensor temperature more than 262°F (128°C)? If yes, go to step 9. If no, go to next step. 8.Check the signal circuit of the IAT sensor for an open circuit or high resistance. Did you find and correct the condition? If yes, go to step 15. If no, go to step 12. 9.Check the IAT sensor low reference circuit for high resistance or an open. Did you find and correct the condition? If yes, go to step 15. If no, go to step 12. 10.Check the IAT signal circuit for a short to any 5-volt reference circuit. Did you find and correct
9/6/2008
Page 3 of 3
the condition? If yes, go to step 15. If no, go to next step.
NOTE: The sensor may be damaged if the circuit is shorted to a voltage source.
11.Check for an intermittent and for a poor connection at the IAT sensor. Repair as necessary. Did you find and correct the condition? If yes, go to step 15. If no, go to step 13. 12.Check for an intermittent and for a poor connection at the PCM. Repair as necessary. Did you find and correct the condition? If yes, go to step 15. If no, go to step 14. 13.Replace the IAT sensor. After repair, go to step 15. 14.Replace PCM. See POWERTRAIN CONTROL MODULE in appropriate REMOVAL & INSTALLATION article. Perform PCM relearn procedure. See POWERTRAIN CONTROL MODULE REPROGRAMMING under PROGRAMMING. After replacing PCM, go to next step. 15.Clear the DTCs using a scan tool. Turn ignition switch to OFF position for 30 seconds. Start the engine. Operate the vehicle within the Conditions for Running the DTC. See CONDITIONS FOR RUNNING DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records. Does the DTC run and pass? If yes, go to next step. If no, go to 2. 16.Observe the CAPTURE INFO using a scan tool. Are there any DTCs that have not been diagnosed? If yes, go to DIAGNOSTIC TROUBLE CODE DEFINITIONS. If no, system is okay at this time.
Diagnostic Aids
When the vehicle is at ambient temperature the IAT sensor and ECT sensor temperatures should be relatively close to each other. See TEMPERATURE VS. RESISTANCE table.
If a short to a separate 5-volt source occurs this DTC may set. If this condition exists, a continuity test to all other PCM 5-volt reference circuits will be necessary.
If an intermittent condition is suspected, refer to INTERMITTENTS in TROUBLE SHOOTING - NO CODES - 2.2L ALERO, CAVALIER, GRAND AM & SUNFIRE - GASOLINE article.
© 2007 Mitchell Repair Information Co., LLC.
9/6/2008
