Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
2003 Chevy Astro V8 All Wheel Drive Automatic 69000 miles
I have a 2003 Chevy Astro AWD van with 69000 miles. The ABS light started coming on at odd times and then going off. Also at times, the ABS would kick in when braking at a normal stop. It makes a "BZZZZ" sound and is sometimes hard to stop. The light coming on and the braking problem are not at the same time usually.
I took it to a trusted mechanic and they said the light code was giving several different errors, so they tried cleaning the contacts to see if that would fix it. They said if the wheel bearing needs replaced that the part alone would be over $400.
It was all right for one day and then started with the same problems, though less frequently. Someone else told me the sensor for the ABS is in the wheel bearing and that is why it is so expensive.
Is this true about the sensor location and price? Is this something we could fix ourselves? My husband is quite experienced at older model repairs.
I'm having the same issue with my '03 AWD. Did changing the wheel sensor fix the problem? Did the codes indicate which sensor(right or left) was causing the problem?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
