Auto Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 Cadillac CTS White Smoke
Posted at Sat Nov 07, 2009 4:43 pm |
By
Melissa2021,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
2003 Cadillac CTS 6 cyl All Wheel Drive Automatic
we just did the oil change on the car this morning n theres white smoke coming out the exhaust.... |
Find a
car repair manual for your Cadillac CTS Repair Question.
Posted at Sun Feb 28, 2010 9:22 pm |
By
Ernest Clark,
Certified ASE Technician |
 (847) Give Feedback | Votes: 8 |
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned. Next could be antifreeze when it is being burned it has a sweet type of smell and tends to dissipate in the air rather quickly. Next is automatic transmission fluid which is normally found on automatic transmissions and its normally drawn into an engine thru a vacuum line via a defective transmission modulator valve or some other defective part. Transmission fluid is very apparent and billows out so bad that you can't see anything behind you.
First try smelling your tail pipe right after you shut the engine off. If it's sweet, it's coolant. If it's burnt smell, it's oil. You could also run your finger inside the tip of the tail pipe. It'll be black, but if it's an oily residue, then it's oil. If it's shiny and clear, it's coolant.
If it's oil, first check the PCV valve for a stuck open valve. (Shake it next to your ear. If it rattles, it's GOOD, if it doesn't, it's BAD) If that checks out good, then you either have worn valve guides or piston rings.
If it's coolant, you either have a blown head or intake gasket. (Both very costly) |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
