Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Nissan Maxima Hard ...
Auto Repair1996 Nissan Maxima
Auto Repair2001 Nissan Maxima Car S...
Auto Repair1990 Honda Civic Heat Gauge
Auto Repair2005 Volkswagen Jetta Gl...
Auto Repair2001 Volkswagen Jetta Al...
Auto Repair2002 Volkswagen Eurovan ...
Auto Repair1995 Volkswagen Eurovan
Auto Repair1998 Other Volkswagen Mod...
Auto Repair1976 Other Volkswagen Mod...
Auto Repair1978 Other Volkswagen Mod...
Auto Repair1995 Nissan Pathfinder
Auto Repair2001 Other Volkswagen Mod...
Auto Repair1968 Other Volkswagen Mod...
Auto Repair2000 Honda Civic Overhea...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2003 Buick Rendezvous gas leaks at filter
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Apr 24, 2008 5:03 pm
By kayla1, New to the forum
Give Feedback | Votes: 0
Smells problem
2003 Buick Rendezvous 6 cyl All Wheel Drive Automatic 40000 miles
I have gas leaking under the drivers side under the car. I looked and saw filter looking little tank with the gas line connecting on both sides.Is this the filter and if so how do I replace it?
Find a repair manual for your Buick Rendezvous Repair Question.
By Advertisment,
Posted at Mon Apr 28, 2008 7:22 pm
By dennyp, Tech level 7
Reputation: 94.4Reputation: 94.4Reputation: 94.4Reputation: 94.4Reputation: 94.4 (94) Give Feedback | Votes: 5
Fuel Filter Replacement
Removal Procedure
Notice: Cap the fittings and plug the holes when servicing the fuel system in order to prevent dirt and other contaminants from entering the open pipes and passages.
Important: Always maintain cleanliness when servicing fuel system components.
Important: There is not any service interval for in-pipe fuel filter replacement. Only replace the in-pipe fuel filter if the filter is restricted.
Relieve the fuel system pressure. Refer to Fuel Pressure Relief .
Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the quick-connect fitting (1) at the inlet of the in-pipe fuel filter. Refer to Plastic Collar Quick Connect Fitting Service .
Drain any remaining fuel into an approved gasoline container.
Remove the in-pipe fuel filter mounting bracket nut (1) from stud.
Remove the quick-connect fitting (2) at the outlet of the in-pipe fuel filter. Refer to Plastic Collar Quick Connect Fitting Service .
Remove the in-pipe fuel filter from the in-pipe fuel filter mounting bracket.
Installation Procedure
Notice: Always re-attach the fuel lines and fuel filter with all original type fasteners and hardware.
Do not repair sections of fuel pipes.
Remove the protective caps from the new in-pipe fuel filter.
Slide the in-pipe fuel filter into the in-pipe fuel filter mounting bracket.
Connect the quick-connect fitting at the outlet (2) of the in-pipe fuel filter. Refer to Plastic Collar Quick Connect Fitting Service .
Install the in-pipe fuel filter and mounting bracket.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the in-pipe fuel filter mounting bracket retaining nut (1).
Tighten
Tighten the in-pipe fuel filter mounting bracket nut (1) to 10 N·m (89 lb in).
Connect the quick-connect fitting at the inlet (1) of the in-pipe fuel filter. Refer to Plastic Collar Quick Connect Fitting Service .
Lower the vehicle.
Reconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
Inspect for fuel leaks.
9.1. Turn ON the ignition for 2 seconds.
9.2. Turn OFF the ignition for 10 seconds.
9.3. Turn ON the ignition.
9.4. Inspect for leaks.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
