Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
2003 Buick Rendezvous communication problem possibly due ha
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Thu Aug 07, 2008 4:28 pm |
By
MZ,
Have Donated |
Give Feedback | Votes: 0 |
Computer problem
2003 Buick Rendezvous 6 cyl Front Wheel Drive Automatic 56000 miles
BCM module seems to be loosing power. Allarms keep on going off in random. They reset or trigger when tapped on stearing wheel. Buick dealer mechanic works on it for last four weeks. He changed BCM - no improvement. He plugged in temporary or disconnected a number of switches and sensors that work with BCM - no improvement. He found couple wires with stripped unsulation - no improvement after repair. Mechanic is still going through ground points, wires and connectors. Problem affecr a power in a way that there are no codes set indicating problem. Diagnostics check o.k. or don't work at at all due to interrupted communication.
After 4 weeks - it looks like a challenge. What would you say gentelmen ?
| Find a
car repair manual for your Buick Rendezvous Repair Question. |
Posted at Thu Aug 07, 2008 11:16 pm |
By
MZ,
Have Donated |
Replacing ignition switch didn't fix a problem. This was tried in a the week #1.
| Find a
Posted at Sun Aug 10, 2008 7:52 pm |
By
MZ,
Have Donated |
On Friday 08/08 I picked up my car from dealer's service shop. Technician told me that he checked all ground/chsse termination except those under seats under carpet. He checked connectots on harness, wiggled wires in search for breaking conductors. There was no definitive find. They put 186 miles driving car without reoccurence of problem. They concluded they hopefuly problem was in one of chssis terminations of ground wire and it was taken care of.
After driving car for two days without incident, it finaly happened just about an hour ago. After cars been switched on a driveway I decided to move up Randezvous a little closer up the driveway to clear a sidewalk. To my supprise engine wouldn't start. I could hear control relay click-in, but starter's bendix never attempted to kick-in. I had this symptom as one of many along with loosing power on gages, cluster, radio, along with alarms on display and chime going "on" and "off". This time there were no allarms.
-- Correction. I wasn't shure if the radio was going off so I went to check. This time engine started o.k. from a first try.
I hope you understand that it is not my best day or month in my life. I need this car to become again reliable.
Any ideas?
| Find a
Posted at Sat Aug 16, 2008 10:53 pm |
By
MZ,
Have Donated |
Problem with start failure had been rectified. After changing BCM module the technician had only one key. Car failed to start with a second key. I programed BCM for it and it's O.K. now. It means that car shows no ill simptoms after picking it up last time from the dealer's shop. It means also that I will never be able to pinpoint exactly where the problem was. I assume - it was one of grounds or connectors - but wchich one? I hope it will not ever come back to hunt me. Thank you for your concern and help.
MZ
| Find a
Posted at Thu Aug 21, 2008 11:37 am |
By
MZ,
Have Donated |
BCM was replaced only once.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
