Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
2003 Buick Century 6 cyl Two Wheel Drive Automatic
Car willl not start when ignition key is turned. Have checked battery and some fuses. No results. Any suggestions?
Does the battery have a full charge, are the cables clean and tight on both ends? If your saying the starter won't crank, I'd do some testing at the starter relay in the power distribution center, under the hood. Remove the relay, turn the key on, you don't have to crank it, use a test lite, two terminals should be hot, are they?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
