Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
2003 BMW X5 6 cyl All Wheel Drive Automatic 71,243 miles
My Rear Passenger window will not go up. I tried replacing T-Bar and also Motor on door. Neither worked. Any other ideas to repair. BMW wants $600 to diagnose.
Thanks
Is the motor not working? It may be the drivers door switch module as it is the master controller for the window motors. It could also be the conductor or connector.
Is the motor not working? It may be the drivers door switch module as it is the master controller for the window motors. It could also be the wiring(conductor) or one of the connectors or a loose ground.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
