Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2003 BMW 525 6 cyl Front Wheel Drive Automatic 45000 miles
Engine light is on and the code saids the engine is running lean.
It is possible there is an intake leak and it might be at the boot from the intake manifold to the air mass sensor. Inspect the small hose that has several bellows in it that serves the idle air control motor that is just to the side of the intake manifold. the part# is 13-54-1-437-191. Let me know if this fixes the problem or if I can help you out with further diagnostics.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
