Posted at Sun Mar 23, 2008 7:32 am |
By
StephClay,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2003 BMW 325 4 cyl Front Wheel Drive Automatic 119000 miles
About 6 months ago my oil light came on so I added a quart of oil to raise level back up and then had oil changed.....no problems til last night when oil light came back on....so I again added a quart of oil. It has been around 4 months since my oil change. I also noticed some oil on my garage floor....not much but about an area of 2"x2".....it idled for a few mins in an open garage so that i could have light putting oil in. I'm worried because I have also seen oil spray on the windshield wiper fluid housing and on the cooling housing. The drip that is under the car is coming from the center of the car in front. I am using a full synthetic 5w30 and live in central ky where it gets pretty cold. Can you lead me in the right direction before I take this car in to be looked at by a mechanic so that I don't seem like a ditzy girl? I only noticed the oil sprays because I was using a flashlight to see if anything looked out of place....not that I would really know if it was.
Thank you for your help!!
Stephanie
| Find a
repair manual for your BMW 325 Repair Question. |
Posted at Sun Mar 23, 2008 7:56 am |
By
merlin2021,
Certified 2CarPros Master Technician |
                       (476) Give Feedback | Votes: 42 |
First thing is add oil only when you have checked the stick, engine off, and on level ground, if you add too much, it's just as bad as not enough! Next, I worked on one a few years ago, and found the oil sending unit was cracked, and the oil pumped up thru the conduit to the top of the motor and sprayed all over the place, Before I found this for a co worker, he had spent 3000.00 on repairs he never needed! I wish I had got all that!
| Find a
Posted at Sun Mar 23, 2008 8:45 am |
By
StephClay,
New to the forum |
| merlin2021 wrote: | | First thing is add oil only when you have checked the stick, engine off, and on level ground, if you add too much, it's just as bad as not enough! Next, I worked on one a few years ago, and found the oil sending unit was cracked, and the oil pumped up thru the conduit to the top of the motor and sprayed all over the place, Before I found this for a co worker, he had spent 3000.00 on repairs he never needed! I wish I had got all that! |
I think I'm okay on the level.....I just don't want to cause more damage that is going to cost me alot of money. I'm a single mother and not getting any monetary help/payment from my ex husband. Is there anything I should really keep an eye on if I have to wait a few weeks before I can afford the repair?
Thank you for the quick response!
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more. |
