Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Toyota Camry Engine dies after slowing to stop
Posted at Sat Nov 07, 2009 5:17 pm |
By
dan1115,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
2002 Toyota Camry 6 cyl Front Wheel Drive Automatic 107000 miles
When slowing to a stop after driving for a while, the engine dies. It usually will not start unless one of the following is done: step on the accelerator or turn off the air conditioner. When it is restarted the idle is about 150 rpm slower than normal. If you then drive it and stop after a bit, the idle RPM is back to normal. Very hard to recreate.
Whenever the dying is happening the rpms are lower than normal.
Thanks. |
Find a
car repair manual for your Toyota Camry Repair Question.
Posted at Sat Nov 07, 2009 5:49 pm |
By
stevew84,
Loves to solve a problem! |
(732) Give Feedback | Votes: 6 |
any codes? check engine light on? |
Find a
Posted at Sat Nov 07, 2009 7:30 pm |
By
dan1115,
New to the forum |
no check engine. no codes. |
Find a
Posted at Sat Nov 07, 2009 7:35 pm |
By
stevew84,
It sounds like you might have a throttle body problem with the IAC. Pretty sure that particular make and model has an electronic throttle body. I would cleaning it first. Make sure the key is off when you clean it. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
