Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
2002 Toyota Camry 6 cyl Two Wheel Drive Automatic 150k miles
2002 Camry v6 auto battery died. Replaced battery- will run but will not idle. all fuses ok. Scanned ecu pulled a P 1128 code. Attempted to adjust Tps to 18%, cleared code and engine will idle w/ ac off. ac on will cause a huting idle. code has yet to return in appx 50mi. need to test Throttle motor, or a slam dunk part swap?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
