Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
2002 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 94000 miles
2002 Silhoutte, dual climate zones with rear controls as well. Front (both zones) blow cold while rear blows hot. Please advise.
Find a car repair manual for your Oldsmobile Silhouette Repair Question.
Need to check the temp blend door in the rear of the vehicle, sounds like it isnt switching like it is supposed to. Look under the vehicle for the a/c and heater lines, the plenum is above that inside, you will have to remove a few interior panels to get access
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
