Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1991 Gmc Jimmy Carbonmo...
Auto Repair2002 Dodge Stratus Heat...
Auto Repair2000 Dodge Stratus Brok...
Auto Repair1989 Holden Commodore
Auto Repair2000 Dodge Stratus Ther...
Auto Repair1989 Chevy Cavalier Car...
Auto Repair1996 Dodge Stratus Engi...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Nissan Pathfinder 2002 Nissan Pathfinder Overheating
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Sep 05, 2008 6:13 pm
By fsevans, Have Donated
Give Feedback | Votes: 0
Engine Cooling problem
2002 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic 106K miles
Working on an overheating issue. When the engine is brought up to operating temperature, the heat blows cool unless you race the engine. It will then blow hot, but after about two minutes, it's blowing cool again. All the while the engine is getting hotter and hotter, to the point it will overheat if you allow it to. I already bled the cooling system, however never really got a solid stream of coolant out of the bleeder tube until it was at the overheating point. Replaced the lower T-Stat and no difference. My question is this: Will the upper T-Stat (water control valve) cause the vehicle to overheat if it is bad? Or is it strictly to control the water to the heater core? I'm not about to pull the intake and waste my time if totally unnecessary. Also, the fan clutch, radiator cap, radiator, and water pump are fine. Thanks in advance for any help you can offer and sorry for writing a book on this one.
Find a car repair manual for your Nissan Pathfinder Repair Question.
Posted at Sat Sep 06, 2008 1:39 am
By BMRFIXIT, Moderator
Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514Reputation: 514 (514) Give Feedback | Votes: 18
To me sounds as its low on coolant
or u have an air trapped inside the engine I suggest follow coolant system bleeding steps below and also check the radiator cap
COOLING SYSTEM BLEEDING
WARNING: To avoid being scalded, never change engine coolant when engine is hot. Wrap a thick cloth around cap and carefully remove. First, turn a quarter turn to release built-up pressure, then turn cap all the way. Be careful not to allow engine coolant to contact drive belts.
1.Turn ignition switch to ON position. Set temperature control to maximum heat position. Turn ignition off after air mix door moves to HOT position.
2.Open radiator drain plug at bottom of radiator, and remove radiator cap. Remove reservoir tank and drain coolant. Clean reservoir tank. Remove cylinder block drain plugs and air relief plugs. See Fig. 1 and Fig. 2 . Check drained coolant for contaminants such as rust, corrosion or discoloration. If contaminated, flush engine cooling system.
3.Install reservoir tank, radiator drain plug and cylinder block drain plugs. Tighten fasteners to specification. Fill radiator slowly to allow air to escape. Install each air relief plug when coolant overflows. Tighten fasteners to specification. Fill coolant reservoir to MAX mark.
4.Start and warm engine to normal operating temperature without radiator cap installed. Run engine at 3000 RPM for 10 seconds and return to idle speed. Repeat 2-3 times. Turn engine off.
5.Check coolant level. Refill coolant reservoir to MAX mark, and repeat step 4 until coolant level no longer drops. Warm engine to normal operating temperature. Move heater control between COOL and HOT positions. Increase engine speed to 3000 RPM. Listen for coolant flow at heater valve. If coolant flow is heard, bleed air from cooling system by repeating step 4 until coolant level no longer drops. Check air relief and drain plugs for leaks.
Posted at Sat Sep 06, 2008 5:27 am
Shouldn't have air in it as it was doing this before the T-Stat was changed. Coolant level is fine. Radiator cap replaced, no change. Still have the question out there of the water control valve. Will it cause the engine to overheat (restrict water flow through the cooling system) if it is bad, or is it more like a bypass in the system to accept water for the heater core??
Posted at Sat Sep 06, 2008 10:53 am
Its just a gate or a door to allow coolant to the heater core
will not make engine overheat
at this point then if you are sure that you have bleed the system using the correct procedure I would suggest having a headgasket test and water pump
good luck
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
