Air Conditioning problem
2002 Mercury Sable 6 cyl Front Wheel Drive Automatic 93000 miles
When trying to use A/C all I get is heat in all modes.Compressor is running and seems to be cold.Could it be the temperature sensor and if so is it located on the temp control panel?Should this pull out after releasing the four corner posts? What else would make it produce only heat?
