Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Toyota Corolla Mis...
Auto Repair1999 Honda Accord Suspe...
Auto Repair1993 Mercury Cougar Win...
Auto Repair1997 Ford Ranger Check ...
Auto Repair1999 Kia Sephia Looking...
Auto Repair2004 Mitsubishi Eclipse ...
Auto Repair2005 Nissan Altima No I...
Auto Repair More Repair Topics...
Car Repair Chat - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Lincoln LS Please Help
Posted at Fri Jul 03, 2009 3:36 pm
By curriercarlson85, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
2002 Lincoln LS V8 Front Wheel Drive Automatic 75000 miles
I recently acquired an 02 lincoln ls and have had a few major issues come up in the short time that ive had it..
check engine light keeps blinking and according to manual it is the exhaust causing this. had the exhaust replaced still comes on.
started to over heat and the culprit was believed to be the thermostat, replaced it and within 20 min all water from resevoir drained to driveway.
there is oil in the air intake line driver side and oil in the rear 2 plugs on driver side.
think it may be head gasket but there is no white smoke no matter what..
any ideas???
Find a car repair manual for your Lincoln LS Repair Question.
Posted at Fri Jul 03, 2009 3:54 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6 (8489) Give Feedback | Votes: 230
Problem 1
CEL On scan the computer for code/s again might no be coming from the exhaust system.
Problem 2
Overheating could be airlock in the system after thermostat replacement try bleeding it-Don't work get the cooling system block and pressure tested to rule out a blown headgasket, cracked head or block
Posted at Fri Jul 03, 2009 4:14 pm
How much n where could i take it get it checked for that as system was bled properly.. it drained all fluid out of block but no leak from block just back behind resevoir
Posted at Fri Jul 03, 2009 5:04 pm
is it possible that its the water pump. friends toyota had same problem with it leaking coolant near the heater core
Posted at Sat Jul 04, 2009 2:00 pm
To confirm the water pump
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
