Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Jaguar XK8 How to replace thermostat
Posted at Sat Nov 21, 2009 7:55 am |
By
Will the Drill,
New to the forum |
Give Feedback | Votes: 0 |
Engine Cooling problem
2002 Jaguar XK8 V8 Two Wheel Drive Automatic 64000 miles
How do I replace the thermostat on my 2002 Jaguar XK8? Engine is a 4 litre. I have the required parts from my Dealer. |
Find a
car repair manual for your Jaguar XK8 Repair Question.
Posted at Sun Nov 29, 2009 7:51 pm |
By
Dave H,
Certified 2CarPros Technician |
           (5878) Give Feedback | Votes: 75 |
THERMOSTAT - VEHICLES WITHOUT: SUPERCHARGER
Removal
Open the engine compartment and fit paintwork protection sheets.
Drain the radiator. Refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING - VEHICLES WITHOUT: SUPERCHARGER. Retain the coolant drain tray in position to catch any spillage when removing the thermostat cover.
Remove the engine cover panels for access.
Disconnect the radiator bottom hose from the thermostat cover.
Release and reposition the hose clip, and disconnect the bottom hose from the thermostat cover.
Fig. 84: Disconnecting Radiator Bottom Hose From Thermostat Cover
Courtesy of JAGUAR CARS, INC.
Remove the thermostat cover.
Remove the three bolts which secure the thermostat cover to the housing. (1)
Remove the thermostat cover from the housing. (2)
Fig. 85: Removing Thermostat Cover
Remove the thermostat from the housing.
Remove the thermostat from the housing. (1)
Remove (and discard) the seal from the thermostat. (2)
Fit a new seal to the thermostat. The seal may be fitted either way round.
Fig. 86: Removing Thermostat From Housing
Installation
Installation is the reverse of the removal procedure.
Fit the thermostat so that the vent ball valve locates in the recess in the cover.
Tighten the thermostat cover bolts to 8-10 Nm.
Fig. 87: Tightening Thermostat Cover Bolts
Refill the cooling system as described. Refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING - VEHICLES WITHOUT: SUPERCHARGER.
THERMOSTAT - VEHICLES WITH: SUPERCHARGER
Removal
Drain the radiator. Refer to COOLING SYSTEM DRAINING, FILLING AND BLEEDING - VEHICLES WITH: SUPERCHARGER. Retain the coolant drain tray in position to catch any spillage when removing the outlet pipe.
Disconnect the bottom hose from the coolant outlet pipe.
Release and reposition the hose clip.
Disconnect the bottom hose.
Fig. 88: Disconnecting Bottom Hose From Coolant Outlet Pipe
Remove the thermostat from the outlet pipe.
Remove the three bolts which secure the thermostat cover to the outlet pipe. (1)
Remove the thermostat cover, the thermostat and the seal from the outlet pipe. Discard the seal. (2)
Fig. 89: Removing Thermostat From Outlet Pipe
Installation
Use new sealing rings on the coolant outlet pipe and thermostat housing.
The thermostat ball valve must locate in the recess in the cover.
Refill the cooling system as described COOLING SYSTEM DRAINING, FILLING AND BLEEDING - VEHICLES WITH: SUPERCHARGER. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
