Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2002 Hyundai Elantra 4 cyl Front Wheel Drive Manual 118000 miles
I am losing power when going up hills and when you first pull out. The rmp's are fine, it idles fine, but just looses power. I can have the pedal all the way to the floor and not pick up speed.
Take top timing cover off and check belt condition if you haven't already changed it. if that's not the issue check fuel pressure if fuel pressure is less than 49.8 psi you have a fuel issue. then change fuel filter if you haven't already then recheck fuel pressure. If that still doesn't fix it check for a fuel blockage and finally key in on the fuel pump. Next check for a clogged cat or resonator. hope this helps
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
