Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1989 Chevy Cavalier Car...
Auto Repair1996 Dodge Stratus Engi...
Auto Repair1996 Pontiac Transport ...
Auto Repair2001 Dodge Stratus Cyli...
Auto Repair2001 Dodge Dakota Rear ...
Auto Repair2004 Dodge Stratus Clue...
Auto Repair1993 Honda Civic Distri...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Honda Civic Slow to start
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Aug 28, 2008 11:57 am
By Liddy, Likes cars!
Give Feedback | Votes: 0
Electrical problem
2002 Honda Civic 4 cyl Front Wheel Drive Automatic 47,800 miles
Honda Civic LX 2002, 47, 800mi.- slow to start after key is turned-
I took my car to a Honda dealer who did not use the OBDII on my car, but told me my fuel pump was shot.
I left w/o the repair, but I did replace the Fuel Pump Sensor.
Problem remains.
I contact another Honda dealer who said: Main Relay. I replaced that. Problem remains.
I replaced my battery. Problem remains.
Plugs only 2months old.
Air filter and oil change recent change.
No warning lights in dash.
Had an auto parts store put an OBDII on it: no warning codes.
What is the problem, PLEASE!!!!
Find a car repair manual for your Honda Civic Repair Question.
Posted at Fri Aug 29, 2008 1:03 pm
By KHLow2008, Moderator
Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7 (179) Give Feedback | Votes: 13
Hi Liddy,
I would suggest testing the fuel pressure and checking the injectors.
Are the sparks at plugs good?
Posted at Fri Aug 29, 2008 4:02 pm
Thank you for the response.
When the dealer said: fuel pump shot, he had done a check. He did not say injectors were a problem: he said they were okay.
Honda plugs are only about 2 months old. The engine will turn over but, it's slow to do so.
I recently was told it maybe the starter switch. I'm going to change that.
Anymore thoughts on this subject would be appreciated.
Thank you all !!!!
Posted at Sat Aug 30, 2008 4:25 am
Hi Liddy,
You mean the cranking speed is slow?
If thet is the case, you need to check
1. Battery voltage and high rate discharge.
2. Battery terminals connections, cables and ground straps.
3. Starter.
Should not be ignition switch if cranking is slow but can be if it does not fires up.
Understand there is a recall for ignition switches, call the dealer and enquire if your vehicle is on the list.
Posted at Sat Aug 30, 2008 6:58 am
Thank you again for your responses!!!!
It is a new battery (2 weeks old) and there appears to be noticeable wear and tear on any cables or wires-this car has 47,900 miles for being a 2002. Trust me, the biggest thing this car has ever done was drive from the east coast to the southwest (1) time. I use it ONLY for around town. I had it thoroughly checked out by the dealer before I made my move here.
This n-n sound than the car starts -started doing this 3 weeks ago. It use to just turn over after I turned the key.
I changed the power relay and fuel sensor, also !
I don't consider anything I have changed out to be a waste of money-it's just par for the course. But I will not, nor do I like being jerked around for repairs I KNOW in my heart I don't need; aka fuel pump, LOL's
I already asked two Honda dealers here if there were any recalls on my car: both said NO! So what am I suppose to do?
Posted at Sat Aug 30, 2008 8:19 am
Hi Liddy,
Did you try jump starting ?
I would suggest servicing the starter for a start.
Posted at Tue Sep 02, 2008 5:08 pm
By 02bluecivic, Likes cars!
My 02 civic 56,000 miles is having the same problem. It runs great just has a hard time starting. Some times up to 4 or 5 seconds of cranking. Battery checks out fine as does the starter. New plugs and clean air filter. Going to talk to honda tomorrow.
Posted at Thu Sep 04, 2008 4:14 pm
liddy
do you have an after market alarm or remote start?
Have you changed any relays under the steering column?
Posted at Mon Sep 08, 2008 6:19 pm
Hey liddy,
I spent a few hours today working on mine. I took it to my honda dealer and went over a bunch of things. Today my car finally though a check engine code which included everything on the fuel side. Included is the fuel pump and possibly vacuum line or O2 sensor. They are leaning toward the o2 sensor. Had to order it in and will be here tomorrow. Let you know the results.
Posted at Tue Sep 09, 2008 4:00 pm
found my problem.
a line got pinched on my fuel pump and had a little hole in it. Replaced the hose and starts and runs fine now. Good luck to you
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
