Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Ford Ranger Light Problems
Posted at Sat Nov 21, 2009 4:35 am |
By
budfu1985,
New to the forum |
Give Feedback | Votes: 0 |
Electrical problem
2002 Ford Ranger 6 cyl Two Wheel Drive Automatic 77000 miles
I just bought this truck and like an idiot, did not check EVERYTHING. Well, the parking lights, brake lights, dash lights, or fog lights don't work, but the headlights, reverse lights, hazards lights, and signal lights work fine (at least for now). I replaced the parking light bulbs before I knew about the other problems and I checked all of the fuses. I didn't check to see if the right fuse was in the right place because the truck didn't come with a fuse panel diagram. What do you think my problem is?...and thanks! |
Find a
car repair manual for your Ford Ranger Repair Question.
Posted at Sat Nov 21, 2009 2:20 pm |
By
jdl123,
Moderator |
     (3072) Give Feedback | Votes: 92 |
Welcome to the forum, does the highmount brake lite work? Check the feed to and from the brake switch, located, brake pedal support. Lite green wire with red tracer carries voltage to brake switch. When brake switch is activated, solid lite green wire goes hot. Voltage for brake circuit, fuse 13-- 20 amp, in fuse box, behind left side of dash. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
