Transmission problem
2002 Ford Mustang 6 cyl Two Wheel Drive Automatic
i have a 2002 ford mustang that will not come out of park when i press the brake down but if i turn it off and pull the emergency brake it will shift through the gears and i can put it in neutral and start it then put it in drive or reverse but if i put it in park i have to turn it off again and use the emergency brake trick again. what would cause this and any ideas about how much it would cost to get fixed
