Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1995 Pontiac Bonneville ...
Auto Repair1999 Porsche 911 Abs An...
Auto Repair1994 Ford Escort Ran Ou...
Auto Repair1992 Honda Accord Fuel
Auto Repair1989 Mitsubishi Truck
Auto Repair1986 Mercedes Benz 300e ...
Auto Repair1995 Toyota Camry Cigar...
Auto Repair More Repair Topics...
We are the Auto Repair Experts!
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Ford F150 passive anti-theft system
Posted at Fri Nov 20, 2009 9:49 am
By claycampbell25, Have Donated
Give Feedback | Votes: 0
Computer problem
2002 Ford F150 6 cyl Two Wheel Drive Manual 100009 miles
I believe that my Anti-theft system has been trigerred and I have done everything I can possibly think of to fix it, including disconnecting battery to changing and checking fuses.How can I reprogram the reciever/transmitter?I have original keys to the truck with no damage to them.
Find a car repair manual for your Ford F150 Repair Question.
Posted at Fri Nov 20, 2009 4:57 pm
By BMRFIXIT, Certified 2CarPros Master Technician
Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2Reputation: 8550.2 (8550) Give Feedback | Votes: 85
Use the key to lock and unlock the door should deactivate the alarm
what do you have for problem ?
with key in and or cranking do you have a security / theft light on or blinking
if not then its not an alarm issue
PROGRAMMING
AUTOLOCK ENABLE/DISABLE
Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled. CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change.
REMOTE TRANSMITTER
Cycle ignition key 8 times within 10 seconds and end in RUN position to enter program mode. Doors should lock and unlock to confirm program mode has been entered. Press any button on Remote Keyless Entry (RKE) transmitter(s). Doors will lock, then unlock to confirm programming. If door locks do not respond, press button again (3 times maximum) with same RKE transmitter. If door locks still do not respond, go to SYSTEM TESTS . Repeat procedure for additional RKE transmitters (4 maximum). If equipped with memory seats, ensure RKE transmitter(s) are programmed according to numbers on back of RKE transmitter(s). Turn ignition switch to LOCK or wait 5 minutes for system to exit program mode. All doors should lock, then unlock to confirm exit of programming mode. Check system operation.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
