Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1992 Honda Accord
Auto Repair2005 Ford F250 Gas Fill...
Auto Repair2005 Buick La Crosse Re...
Auto Repair2002 Cadillac Sls Servi...
Auto RepairOther Ford Models Batter...
Auto Repair2002 Dodge Stratus Heat...
Auto Repair1996 Ford Ranger Wont S...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Ford Escape Rear Latch Not unlocking now not locking
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Apr 30, 2008 4:36 pm
By Heritage1, New to the forum
Give Feedback | Votes: 0
Electrical problem
2002 Ford Escape 6 cyl Four Wheel Drive Automatic 95000 miles
I have a 2002 Ford Escape and occasionally the rear glass and liftgate would not unlock. After trying it and then driving around for awhile it would unlock and I could open it. This was very intermittent and usually would function properly both with the keyless and from the switch on the drivers door. Today, I had the liftgate open and put the latching mechanism in the closed position. Then I used the keyless and screw driver and opened the latching mechanism into the open position. (Why I did this I'm not sure.) Anyway, now I have no problems with the glass or lift gate closing and opening or locking in place, but the latch handle does not lock. So even with the car alarmed I can now open the rear gate and window. Also, without the alarm sounding. So, basically I traded one problem for another. I was probably better off before. Should I just replace the latching mechanism or is there something with the alarm / locking system that could just be reset. Thanks!
Find a car repair manual for your Ford Escape Repair Question.
Posted at Mon May 26, 2008 12:19 pm
By sjchampion, New to the forum
I just had my actuator fail so it would no longer lock unlock automatically. Using the key would work fine.
I was cheap and bought a new one at nearby electronics store for $18. I've seen online versions for $6. It took extra effort/time, but better than buying a full latch mechanism - I've heard over $150 plus labor if you can't do it yourself.
SO. During this ordeal, I had the same problem you described. Close door, open latch and use screw driver to pretend you are latch door. Push inside latch mechanism/catch with flatblade screwdriver to engage and lock it. Use the handle to unlock. Now try closing your glass latch door - it should work now.
Also, there is a recall related to the rear latch mechanism. Try to get this checked out - see if you can avoid the hassle all together and get it for free.
Good luck.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
