Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Dodge Stratus Creaky car
Posted at Fri Oct 16, 2009 1:32 pm |
By
j_DUB,
New to the forum |
Give Feedback | Votes: 0 |
Noises problem
2002 Dodge Stratus 72,00 miles
My car just recently started creaking. It sounds like it is coming from by the wheels. What could this be and do i need to get it fixed right away? |
Find a
car repair manual for your Dodge Stratus Repair Question.
Posted at Mon Oct 19, 2009 5:34 pm |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
                              (15633) Give Feedback | Votes: 122 |
WHen do you hear the creaking? Does it only happen on bumps, turns, all the time...? |
Find a
Posted at Sat Nov 07, 2009 6:29 pm |
By
j_DUB,
New to the forum |
| Jacobandnickolas wrote: | | WHen do you hear the creaking? Does it only happen on bumps, turns, all the time...? |
mostly all the time. I hear it more often when turning left and on bumps. |
Find a
Posted at Sat Nov 07, 2009 8:16 pm |
By
Jacobandnickolas,
Chances are it is being caused by dry or worn sway bar bushings. They are under the front. THere is a round steel bar that runs from one side to the other. It is mounted in 4 places and rubber bushings hold it in place. When they get older or dry out, the make noise. Check that and let me know. You could even try spraying something like WD40 on the bushings to see if it helps. However, usually the oil doesn't make it the entire way through and it doesn't stop it.
Let me know if you have other questions. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
