The easiest thing to check is the PCM connectors with all these codes there is a power problem to it.
SELF-DIAGNOSTICS -2002 Dodge Intrepid ES
Page 1 of 2
DTC P0351: IGNITION COIL #1 CIRCUIT, DTC P0352: IGNITION COIL #2 CIRCUIT, DTC P0353: IGNITION COIL #3 CIRCUIT, DTC P0354: IGNITION COIL #4 CIRCUIT, DTC P0355: IGNITION COIL #5 CIRCUIT OR DTC P0356: IGNITION COIL #6 CIRCUIT
NOTE: All DTCs listed above are diagnosed using the same test. For component location, see COMPONENT LOCATIONS . For connector identification, see CONNECTOR IDENTIFICATION . For circuit identification and wiring diagram, see WIRING DIAGRAMS article. After each repair procedure has been completed, reconnect all components. Perform POWERTRAIN VERIFICATION TEST VER-5 under VERIFICATION TESTS to ensure system is functioning properly.
Monitored & Set Conditions
Ignition coil primary circuit is monitored when battery voltage is greater than 8 volts during engine cranking or greater than 12 volts with engine running, engine RPM less than 3000, and none of the coils in dwell when checked. DTC will set when peak current is not achieved with battery based dwell plus 1.5 milliseconds of diagnostic offset. It takes less than 3 seconds during cranking or up to 6 seconds while running to set.
Possible Causes
Intermittent Condition
ASD Relay Output Circuit Open
Ignition Coil Capacitor(s) Shorted To Ground
ASD Output Circuit Shorted To Ground
Coil On Plug
Coil Driver Circuit Shorted To Ground
Coil Driver Circuit Open
PCM
Testing
1.Turn ignition on, engine off. With the DRBIII(R), read DTCs and record the related Freeze Frame data. Is the Good Trip counter displayed and equal to zero? If yes, go to next step. If no, go to step 9 . 2.Turn the ignition off. Disconnect the Coil On Plug harness connector related to DTC that is set. Turn ignition on, engine not running. With the DRBIII(R), actuate the ASD Relay. Using a 12-volt test light connected to ground (B-), check the ASD relay output circuit at the Coil On Plug harness connector. Does the test light illuminate brightly? If yes, stop all actuations and go to next step. If no, stop all actuations and go to step 7 .
NOTE: The following resistance measurement should be taken at 70-80°F (21-26°C).
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/14/2008
Page 2 of 2
3.Turn the ignition off. Measure the primary resistance of the Coil On Plug (component side). Is the resistance between 0.6 and 0.9 ohm? If yes, go to next step. If no, replace the Coil On Plug. 4.Ensure ignition is off. Disconnect PCM harness connectors. Measure the resistance between the Coil Driver circuit at the Coil On Plug harness connector and ground. Is the resistance below 5.0 ohms? If yes, repair the short to ground in the Coil Driver circuit. If no, go to next step. 5.Measure the resistance of the Coil Driver circuit from the Coil On Plug connector to the PCM connector. Is the resistance below 5.0 ohms? If yes, go to next step. If no, repair the open Coil Driver circuit.
NOTE: Before continuing, check the PCM harness connectors for corrosion, damage or terminal push out. Repair as necessary.
6.There are no possible causes remaining, replace PCM. Program the new PCM. See PROGRAMMING . 7.Ensure the ignition is off and Coil On Plug is disconnected. Remove the ASD Relay from the PDC. Measure the resistance of the ASD Relay Output circuit between the ASD Relay connector and the Coil On Plug harness connector. Is the resistance below 5.0 ohms? If yes, go to next step. If no, repair the open in the ASD Relay Output circuit.
NOTE: Repeat the following test for both Ignition Coil Capacitors. The Ignition Coil Capacitors are attached to the side of each valve cover.
8.Turn the ignition off. Disconnect the Ignition Coil Capacitor harness connector. Install a good INJ/COIL fuse (fuse S) in the PDC. With the DRBIII(R), actuate the ASD Relay. Is the INJ/COIL fuse okay for both Ignition Coil Capacitor tests? If yes, replace the Ignition Coil Capacitor(s). If no, repair the short to ground in the ASD Output circuit.
WARNING: When the engine is operating, do not stand in a direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing.
9.The conditions that set the DTC are not present at this time. The following may help in identifying the intermittent condition. With the engine running at normal operating temperature, monitor the DRBIII(R) parameters related to the DTC while wiggling the wiring harness. Look for parameter values to change and/or a DTC to set. Review the DRBIII(R) Freeze Frame information. If possible, try to duplicate the conditions under which the DTC was set. Refer to any Technical Service Bulletins (TSB) that may apply. Visually inspect the related wiring harness. Look for any chafed, pierced, pinched, or partially broken wires. Visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals. Were any of the above conditions present? If yes, repair as necessary. If no, test is complete.
Page 1 of 2
DTC P2302: IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT IONIZATION, DTC P2305: IGNITION COIL #2 CIRCUIT-INSUFFICIENT IONIZATION, DTC P2308: IGNITION COIL #3 CIRCUIT-INSUFFICIENT IONIZATION, DTC P2311: IGNITION COIL #4 CIRCUIT-INSUFFICIENT IONIZATION, DTC P2314: IGNITION COIL #5 CIRCUIT-INSUFFICIENT IONIZATION OR DTC P2317: IGNITION COIL #6 CIRCUIT-INSUFFICIENT IONIZATION
NOTE: All DTCs listed above are diagnosed using the same test. For component location, see COMPONENT LOCATIONS . For connector identification, see CONNECTOR IDENTIFICATION . For circuit identification and wiring diagram, see WIRING DIAGRAMS article. After each repair procedure has been completed, reconnect all components. Perform POWERTRAIN VERIFICATION TEST VER-2 under VERIFICATION TESTS to ensure system is functioning properly.
System is monitored with engine running. DTC will set if the PCM detects that the secondary ignition burn time is incorrect or not present. DTC is a one trip fault.
Possible Causes
Spark Plug
Ignition Coil Operation
Ignition Coil
Testing
1.Turn ignition on, engine off. With the DRBIII(R), read DTCs and record the related Freeze Frame data. Is the Good Trip counter displayed and equal to zero? If yes, go to next step. If no, go to step 3 . 2.Turn the ignition off. Disconnect the Ignition Coil harness connector that is related to the DTC that is set. Remove the ignition coil. Before continuing inspect the Ignition Coil for damage or carbon tracking on the Coil or the spark plug insulator boot. Replace Ignition Coil as necessary. If no problem is found, install a spark tester to the Ignition Coil. Reconnect the Ignition Coil harness connector to the Ignition Coil. While cranking the engine, observe the spark coming from the spark tester. The Ignition Coil should generate a crisp Blue spark that is able to jumper the gap of the spark tester. Does the Ignition Coil generate a good spark. If yes, replace the Spark Plug. If no, replace the Ignition Coil. 3.Turn the ignition off. Remove the Spark Plug. Inspect the Spark Plug for the following conditions.
Cracks
Carbon Tracking
Foreign Material
Gap Size Out Of Specification
Loose Or Broke Electrode
8/14/2008
Page 2 of 2
Lightly tap the bottom of the spark plug on a solid surface. The electrode in the spark plug should not move. Were any of the above conditions present? If yes, replace the Spark Plug. If no, go to next step.
4.The conditions that set the DTC are not present at this time. The following may help in identifying the intermittent condition. With the engine running at normal operating temperature, monitor the DRBIII(R) parameters related to the DTC while wiggling the wiring harness. Look for parameter values to change and/or a DTC to set. Review the DRBIII(R) Freeze Frame information. If possible, try to duplicate the conditions under which the DTC was set. Refer to any Technical Service Bulletins (TSB) that may apply. Visually inspect the related wiring harness. Look for any chafed, pierced, pinched, or partially broken wires. Visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals. Were any of the above conditions present? If yes, repair as necessary. If no, test is complete.
© 2007 Mitchell Repair Information Co., LLC.
8/14/2008
