Car Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
2002 Dodge Intrepid Possible faulty computer
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Aug 27, 2008 1:05 pm |
By
jlaudio13w7,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
2002 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 69,000 miles
Well, fella's, I got a good one. I have a 2002 intrepid with the 3.5 SOHC, just shy of 70k miles. My check engine light came on (car ran fine at this point) and when scanned gave codes for defective oxygen sensors (upstream). I replaced both, and did the spark plugs while I was at it. The car only started running rough though! Double checked the sensors, and then even replaced the new ones! Looked on the internet for what else may be wrong. I was influenced to go ahead and replace the upper intake manifold gasket, but it was not the problem. Took the car to a mechanic who advised me to let him change the plugs (he claimed that the bosch plugs I used don't work as well as Champion plugs), and do a fuel system cleaning. It still ran rough. Put a can of fuel injector cleaner in it, still ran rough. The car will miss, stutter, and stumble (sometimes at a stop, sometimes while accelerating). Before allowing the first mechanic to start replacing fuel injectors, I got a second opinion. The second mechanic suggest that the computer needs to be flashed,and can only be done by the dealer. The problem there is that the last time I took the car to the dealer, they were unable to establish communication with the computer (this was when wal*mart destroyed my key trying to make a copy)..walmart refused to pay for the repair, and I am scared that it is coming back to bite my behind.....What can I do?
| Find a
car repair manual for your Dodge Intrepid Repair Question. |
Posted at Thu Aug 28, 2008 3:15 pm |
By
jlaudio13w7,
Have Donated |
I took the car to the dealer today, and they reported no problems with attempting to communicate with the PCM, maybe it was just when they tried to program the BCM. They have suggested that the rear oxygen sensors need to be replaced (I only did the upstream). As far as I knew only the upstream sensors affected the fuel managment...what gives with them?
| Find a
Posted at Wed Sep 03, 2008 12:49 pm |
By
jlaudio13w7,
Have Donated |
So, when I went out to the dealer to talk with them about what was going on. The last time them and I spoke they talked me in to doing the D.S. o2's because they said that since I was already going to have the cost of the diag. fee, that if I brought the new sensors in ( to make sure they were a matching pair with the U.S.o2's I already replaced ) they would install them for no additional cost. After they failed to call me friday evening as they told me they would earlier that afternoon (when I called them, because they forgot to call me) it was all the way till tuesday that I even heard from them. When I went up there tuesday morning the service advisor I had been speaking with all along shows me an o2 sensor off my car (the threads are twisted and broke), he then states he thinks whoever put it in cross-threaded it (it looked like the threaded portion got stretched to me). And then had to wait till wednesday for the service manager to get there. And now here I am with a car that is broke because of a repair I didn't want to do, and only did because the labor (I think the tech. didn't start the car for a bit before removing the sensor!) was free! And you can only guess how much that cat/header/downpipe cost with installation!
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
