Car Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Dodge Dakota door panel
Posted at Fri Jul 03, 2009 12:32 pm |
By
enok62,
Have Donated |
Give Feedback | Votes: 0 |
Interior problem
2002 Dodge Dakota V8 Two Wheel Drive Automatic 88500 miles
something is real loose inside the drivers door. I want to take the inside panel off and have removed three phillip srews. Are there more? Might it be the star screw on the side of the door? How do I proceed?
Thank you |
Find a
car repair manual for your Dodge Dakota Repair Question.
Posted at Fri Jul 03, 2009 6:16 pm |
By
buddycraigg,
Moderator |
(33) Give Feedback | Votes: 22 |
Most inner door panels are attached the same, no matter what kind of car you have.
Generally the outer edge of the panel is held to the metal part of the door with plastic clips. Expect to break about 25% of these when you remove it.
The center part of the panel normally has a few screws that secure it. Sometimes they will have a small cover over them, often the size of a dime. Just for cosmetic reasons.
There will almost always be 1 or 2 screws attaching the pull handle, the place you grab onto to pull the door closed.
Most of the time, there will be a screw somewhere close to lever you use to open the door.
If your armrest is not molded into the door panel, there will be screws that attach it. Often at a 45degree angle coming from the bottom.
And finally, on rare occasion, there will be some screws near the speaker in the door, if you have one.
Armed with this information. This is how remove a door panel that I am not familiar with.
First I remove all of the screws that I can see, and look for anything that may be a cap that is covering a screw.
Second I start at the bottom of the door and try to pull it away from the door. As the plastic clips start to release, I work my way up along the front and rear edge of the door.
Sometimes during this step, I notice the center part of the panel is still attached, and have to search for a hidden screw.
Finally, when the panel is free all the way around, grab the panel along the front and rear edges and pull straight up to get it to release from along where it touches the glass.
I hope this helps. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
