Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
2002 Chrysler Sebring 6 cyl Front Wheel Drive Automatic 28650 miles
The switch to adjust the fan speed inside the car only works in the 4 or highest setting. When set to either 1, 2 or 3 there is no response. Doesn't matter if heat or air.
replace the blower motor resister. this is the problem, they burn out the lower settings. the new part is updated and built stronger, its held in by 2 screws and is located near blower motor in the heater box
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
