Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Chrysler 300 Brake...
Auto Repair1998 Chevy S-10 Headlig...
Auto Repair1974 Other Dodge Models ...
Auto Repair2001 Dodge Dakota Oil Leak
Auto Repair1988 Pontiac Grand Prix ...
Auto Repair2004 Jeep Wrangler Fron...
Auto Repair2002 Lincoln Ls Ball Jo...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Chrysler PT Cruiser Gas Consumtion and Car does not go
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Aug 09, 2008 3:52 am
By Kunle Sadiq, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
2002 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic 110000 miles
The RPM goes up to fast up to 5and red section but the car does not go beyond 50miles per hour however much you press the gas pedal.
In addition, the car comsumes so much gas, double what it should consume or more.
What could be the reason for this ?
Find a car repair manual for your Chrysler PT Cruiser Repair Question.
Posted at Sat Aug 09, 2008 4:29 am
By Service Writer, Certified 2CarPros Master Technician
Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8Reputation: 537.8 (538) Give Feedback | Votes: 72
Does it run rough at all?
Does it pick up speed slowly but engine is revving high?
IS the transmission fluid at the proper level and clean?
IS the idle normal when in park?
Posted at Sat Aug 09, 2008 11:25 am
Thanks for your response.
Yes, the car runs very rough.
You are right. It picks up speed slowly and the engine revs very high afterwards
The transmission is at proper level and clean
The idle is not normal when in park.
What do you think is the problem?
Kunle
Posted at Sat Aug 09, 2008 2:59 pm
I had to differentiate the problem between a transmission or engine performance problem, which is the latter.
One thing that would be good to know is if any codes are in the computer as this maybe a wide variety of possible sources.
On the basics side, how old are the plugs and wires and timing belt.
Again, get the codes read and post them.
I expect there will at least be a misfire code listed.
Posted at Sun Aug 10, 2008 11:47 am
Thanks.
While I was driving the car this morning, the engine stopped running in the middle of the road. Upon checking the car, I discovered that the timing belt is loose.
Meanwhile, I replaced the timing belt about 2 months ago.
The spark plugs were changed at thesame time.The wires were not touched though.
Now I have to replace the Timing belt before I can check the codes.
Could the timing belt be the problem all along?
Can you advise me on how to fix the timing belt and the timing because the mechanics in my country, Nigeria (Africa) are not used to American Made cars and there are no chrysler dealers in Nigeria.
Will appreciate your assisstance.
Meanwhile I just ordered the timing belt from NY. I will get it in few days.
Kunle
Posted at Sun Aug 10, 2008 5:12 pm
Timing belt tensioner went bad is my guess. You moved it a few months back more than it is used to moving and a weak spring got put over the edge.
That was likley the cause of the problems. Be sure to determine why the belt slipped, again, the tensioner is a likely culprit.
Posted at Mon Aug 11, 2008 5:07 am
What is a tensioner and what does it look like.
How do I set the Timing belt. Is there a fixed marker on the car
Posted at Mon Aug 11, 2008 2:38 pm
http://www.autopartswarehouse.com/search/?N=10004+1589+4294967263+9319
This is an interfernece engine, meaning when it goes out of time the pistons and the valves can collide.
There is just too much too pull out for this job from mitchell, IT would be well worth getting a manual on this.
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Posted at Tue Aug 12, 2008 2:20 am
Thanks. Will update you as it goes
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
