Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2002 Chrysler Concorde 6 cyl Two Wheel Drive Automatic 65243 miles
My car was working fine. One day I tried the fuel injector cleaner in the petrol tank. The next day onwards it have starting trouble. The mechanic says the fuel pump problem. Is it because of some kind of dirt block in the pump how can I check it ?
Find a car repair manual for your Chrysler Concorde Repair Question.
Hi:
Yes it could be a fuel pump problem, but it could also be a fuel filter problem. The fuel pump pressure needs to be checked before the fuel filter. If the pressure is good, check it after the fuel filter.
Let me know what you find.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
