Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Chrysler Concorde fuel problem
Posted at Sat Nov 07, 2009 2:36 pm |
By
genoth1,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
2002 Chrysler Concorde 6 cyl Automatic 174000 miles
engine will not go above 2000 rpms, then stalls out. It seems like it might be a fill filter. Where is the fill fitler located. |
Find a
car repair manual for your Chrysler Concorde Repair Question.
Posted at Sat Nov 07, 2009 2:56 pm |
By
rasmataz,
Certified 2CarPros Master Technician |
        (8489) Give Feedback | Votes: 230 |
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires |
Find a
Posted at Sat Nov 07, 2009 3:17 pm |
By
two66mhz,
Likes to hang around! |
(12) Give Feedback | Votes: 0 |
| genoth1 wrote: | Engine Performance problem
There are a couple of fuel filters, on on the pump its self in the tank (not always) and there would be one inline under your car. Been so long since I was under a LH (Concorde), you will want to start at the fuel tank and follow it forward. You should be able to spot it no problem. But, do look at other things too. The list posted is a good place to look. |
Find a
Posted at Mon Nov 09, 2009 9:26 pm |
By
caradiodoc,
Problem solver! |
    (489) Give Feedback | Votes: 8 |
You won't solve a running problem on a Chrysler product by replacing the fuel filter, except on diesels. The largest volume of fuel flows through the filter during coasting. Suspect a filter if the engine dies when removing your foot from the accelerator at highway speeds.
I can't explain why, but I did read about a similar problem caused by an incorrect air gap for the crankshaft position sensor.
caradiodoc |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
