Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2003 Mitsubishi Diamante
Auto Repair1992 Mitsubishi Diamante...
Auto Repair2001 Mitsubishi Diamante...
Auto Repair1999 Ford Crown Victoria...
Auto Repair2002 Mitsubishi Diamante
Auto Repair2000 Mitsubishi Diamante...
Auto Repair2002 Audi Quattro Winds...
Auto Repair More Repair Topics...
Auto Repair Help by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2002 Chrysler Concorde Code P 0153 O2 sensor problem
Goto page 1, 2, 3  Next
Posted at Wed Sep 30, 2009 9:19 am
By James_007, Likes to hang around!
(17) Give Feedback | Votes: 0
Electrical problem
2002 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 134K miles
Hi All,
I've been gathering information about the situation with my Concorde Limited 2002, the internet is a great place. I have little experience with auto mechanical issues but I believe I can replace the O2 sensor myself, there are some online tutorials on utube showing the basic way to do this. My question is, my code displays a "P0153 – 2/1 O2 Sensor Slow Response", this sensor is upstream from the catalytic converter right? I believe there are two O2 sensors upstream and 2 O2 senors downstream, should I replace both that are upstream or just the one on the drivers side?
Any help would be greatly appreciated:)
James
Find a car repair manual for your Chrysler Concorde Repair Question.
Posted at Thu Oct 01, 2009 5:00 am
By Jacobandnickolas, Certified 2CarPros Master Technician
Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8Reputation: 15693.8 (15694) Give Feedback | Votes: 122
To the best of my knowledge, that means bank 2 sensor 1. If you are on the passanger side of the vehicle looking at the engine, bank 2 should be the one on the left.
Posted at Mon Oct 05, 2009 9:32 am
Thanks for your response:)
Just another quick question. If my mileage is not being effected (getting roughly 21 mpg in the city), should I be concerned about the O2 sensor issue. Just wanting to learn more about it, and pick up a hanes manual, so that when I try to change it myself I'm more prepared. I've read in other places if the mileage is not being effected then it is not much of a problem.
Thanks again.
James
Posted at Mon Oct 05, 2009 9:45 am
I agree. If the sensor is bad, it will have an adverse affect on the mileage. If it is still running well, chances are it is just starting to go bad. But, it could cause other items to go bad if not replaced. Therefore, I recommend doing it.
As far as a manual, the sensor just unbolts from the exhaust, unplug the wiring harness, and replace the new one. I recommend using anti seize on the threads so you will be able to remove it in the future if it goes bad again. If you don't, it will rust / corrode and will be nearly impossible to remove.
Posted at Sun Oct 25, 2009 12:08 pm
Just a follow up and a question. I'm starting to notice a MPG deficiency. My car has a trip computer, and I usually keep it on instant MPG setting. When I accerlate it goes down to 5 or 6 instant MPG useage, but I am not pushing it when I accerlate, never going above 2000 rpm, once I get to cruising speed and it kicks into overdrive it lists a instant MPG of 27 to 33 which seems normal to me. Most of my driving time is at the cruising stage, unless I go thru a route with allot of stop light or heavy traffic (these routes I try to avoid). The thing is it is still listing my avergae MPG as 18.5, just below the stated MPG for the 2002 Concorde Limited. I've inflated my tire pressure to 50 psi, I roll to stop lights or down hills by putting car into neutral, trying everything to conserve fuel, still getting below average MPG than what I should be. Must be the O2 sensor right?
I priced it at a shop here for only $155 Canadian to get it fixed, just concerned that they won't fix it right the first time. Interesting thing, before I bought this car, I did a car fax and it listed a O2 sensor replacement back in 04', just doesn't list which one/s.
James
P.S. How accurate is the trip computer regarding MPG readings and miles till empty readings.
Posted at Sun Oct 25, 2009 7:26 pm
The O2 sensor can cause the drop in mileage. As far as the cost of replacement, you could replace it yourself. It's just a matter of unpluging a connector, unscrewing the sensor and replacing it with the new one and plugging it back in.
As far as the tire pressure you are using. Check the sidewall of the tire. Max pressure for passanger tires usually doesn't exceed 44PSI. You could have a blow out and the center of the tires will wear out faster than the outside. Check that to make sure you haven't exceeded the recommended max pressure.
As far as the computer and MPG, they are accurate. However, if the float gauge in the fuel tank goes bad, the miles till empty could be wrong.
Overall, it is very common for O2 sensors to go bad, and yes they will cause poor fuel economy. If you know which one is bad, you could most likely save yourself about 60 or 70 dollars doing it yourself, but that is up to you.
Let me know if you have other qusetions.
Posted at Tue Nov 03, 2009 5:20 pm
Thanks Joe:)
Well I gave in and brought the car in today to get the O2 sensor replaced. They did a scan as well, and the only one that came up was p 0153, the same that came up when I checked it myself, they did this to confirm that the O2 sensor was the problem, I don't mind paying for it as they reset the computer so the engine light would be off. I got the car on the road, then a few hours later, the engine light went on again, flashing this time and at this exact time when I wanted to accelerate the car wouldn't. I pulled over, turned the car off on off on off on to get the code and now it comes up as p 0300, cyclinder misfire. After this when I went to drive the engine light stayed on consistently and at times I did feel a slight slight jerking, only when I was travelling really slow, like in a parking lot.
Obviously I plan to bring it back to the shop that replaced the O2 sensor, but could replacing the sensor cause this problem?
Thanks.
James
Posted at Tue Nov 03, 2009 8:12 pm
James:
I doubt the O2 sensor has anything to do with the new misfire; however, I would return to the place that did the work. They may have moved things around causing a plug wire to short or something to come disconnected. As far as the new code, PO300, I believe that is a random misfire not specific to any particular cylender. WHen was the last tune up?
PS: It sounds like you have the same luck as I do.
Posted at Tue Nov 03, 2009 8:44 pm
James:
Hi Joe,
Oh No, lol.
Well what I find interesting is that this misfire problem happens right after the O2 sensor replacement, so in my mind whatever they did must have done something to bring about this situation. I will test drive it tomorrow to see how the acceleration is while on the way to the shop. Question, if it is just a random misfire, rather than a specific cylinder misfire, is that good or bad?
I just bought this car in August, so I am not sure when the last tune up was, was thinking of getting one done soon anyways.
Thx again.
James
Posted at Wed Nov 04, 2009 6:09 am
Actually, it makes it harder to locate. When there is a specific cylender misfiring, a mechanic can go to that cylender and check it. If it is random, it could be any.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
