Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Honda Accord Squee...
Auto Repair1990 Ford Tempo Noisy E...
Auto Repair2000 Dodge Intrepid No ...
Auto Repair2006 Chevy Impala Car W...
Auto Repair1996 Pontiac Sunfire No...
Auto Repair2003 Chevy Avalanche Oi...
Auto Repair2000 Ford F150 Exhaust!!
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Chevy Venture hesitates upon acceleration really bad f
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Fri Aug 01, 2008 1:45 pm
By lcdouce, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
2002 Chevy Venture 6 cyl Front Wheel Drive Automatic 89000 miles
spits and sputters while you press on the gas . idles fine. when sitting parked, if you press the throttle, it runs choppy. only does this for a little while when driving after the van has been sitting overnight. once running a while, it runs good. All O2 sensors and catlytic convertor have been changed. Is this fuel pump Problem?
Find a car repair manual for your Chevy Venture Repair Question.
Posted at Fri Aug 01, 2008 1:51 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5Reputation: 1003.5 (1003) Give Feedback | Votes: 75
Could be fuel pressure, throttle position/MAF/MAP sensors and the EGR valve opening too soon-problem
Posted at Sun Aug 03, 2008 9:04 pm
By ambryatim, Likes cars!
Not to "thread jack" But, I too am faced with the same problem. My friends van is doing the exact same thing. 2003 Chevy Venture 4.3 V6 roughly 163,000 miles. But, everytime hers hesitated it would log a DTC of P0420 (Cataylist Effiency Below Threshold Bank 1)
She could let it warm up for about 20min and it would drive fine all day.
So, I changed the Cat Conv and the O2 sensor behind the cat. It was fine for about 3 weeks, then hesitated again and logged the same DTC P0420, but went away. I did notice that she has a small exhaust leak and it is getting worse. Could this also cause the P0420 code???
We then it alsmost died on her, the battery light came on for a second and then went out. She revved the van and then drove home. Tested the battery and found it to be bad installed a new battery and will wait and see if she has anymore problems.
Posted at Sun Aug 03, 2008 11:56 pm
False" air can enter the exhaust through leaks and upset the O2 sensor readings
Posted at Mon Aug 04, 2008 6:50 pm
Would the exhaust leak cause it to hesitate???
She drove the van this morning and it gave her troubles for about the first 20min of driving. (But, also during the hesitation period it never logged a code and the light MIL never came on). After that it drove perfectly fine all day with no hesistation.
I dont think it is the fuel pump due to the fact that if she lets the van warm up for about 15mins then dirves it, the van works flawlessly. So, I am still a little frustrated and any help is greatly appreiated.
Posted at Mon Aug 04, 2008 7:01 pm
Wouldn't all of these set a DTC??? I have worked on one vehicle (99 Dodge Stratus) that had an issue with the EGR valve, but it was with "Insufficent Flow" P0401. But, now on this Chevy Venture I get no codes???
Posted at Tue Aug 05, 2008 12:28 pm
Would the exhaust leak cause it to hesitate??? The extra air will cause the oxygen sensor to read lean condition and send this to the computer.
Posted at Tue Aug 05, 2008 3:54 pm
Ok, the exhaust leak is right after the first O2 sensor in the flex joint I will have this repaired and reset the computer and try that out. What about the egr valve would I be able to test it with a vacuum gauge and at what vacuum should it open fully????
Posted at Tue Aug 05, 2008 4:47 pm
So, in essence it would cause the van to run richer than normal right??? If it was sensing it was too lean it would logg a DTC correct??? Well if so then it is not doing it. As for the MAP/MAF sensors what are there values (vacuum/air flow) at idle??? Thank you for all the info.
Posted at Tue Aug 05, 2008 8:37 pm
The EGR valve apply vacuum to it-it should stall or idle erratically. MAP voltage
Idle 1.0-1.5volts
WOT 4.0-4.9 volts
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
