Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Renault Clio Cambelts
Auto Repair2001 Chrysler Sebring
Auto Repair2002 Chevy Blazer Head ...
Auto Repair1991 Volvo 740 Engine D...
Auto Repair1997 Ford Mustang Clutc...
Auto Repair1997 Jeep Wrangler Sway...
Auto Repair1986 Nissan Truck Senso...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Chevy Suburban INSTRUMENT CLUSTER
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Oct 11, 2008 8:46 pm
By chvzkora, Likes cars!
Give Feedback | Votes: 0
Electrical problem
2002 Chevy Suburban V8 Four Wheel Drive Automatic
MY INSTUMENT CLUSTER IN MY 02 SUBURBAN IS NOT WORKING PROPERLY IT SHOWS A BATTERY SIGN ON THE MESSAGE CENTER BUT I HAVE CHECK MY BATTERY AND MY ALTERNATOR AND THEY ARE FINE. ALSO THE WIPERS DONT WORK NEITHER DOES THE AIR CONDITIONER,THE MILEGE, OR THE 4 WHEEL DRIVE, AND THE GAS AND TEMP GAUGES DONT READ ANYTHING. ANY IDEA WHAT THE CAUSE COULD BE
Find a car repair manual for your Chevy Suburban Repair Question.
Posted at Wed Oct 22, 2008 3:57 am
By micxie, Likes cars!
A bare wire somewhere shorted out and blew a fuse. In the engine compartment there is a large fuse box.Remove the cover and check the 50 amp fuses on the top row,one of them has blown. Find and fix the bare wire or this will happen again.
The reason this happens is when there is a short ,the fuse will blow giving an indication that the battery is not charging. then the system will shut down all unessessary electracal components in order to conserve battery power. Hope this solves your problem.Let me know if it does
Mike
Posted at Thu Oct 23, 2008 12:59 pm
i have check my fuses and they are good. my battery even though the dash on the truck has the battery light has not run down it seems like the alternator is charging. the battery light has not turn off and my car runs fine the only problem is that my gauges(fuel and temp),4*4, high beams, air conditioner, mileage and my wipers dont work
Posted at Fri Oct 24, 2008 3:47 am
Hi
Are we talking about the chevy suburban 2002 or the pickup truck. refuring to the 02 suburban,you have blown a fuse somewhere.Did you check all of the 50 amp fuses? by taking them out and looking to see if the contact was burnt? In the engine compartment on the drivers side there is a large black box like component with writing on the top that says Electrical center. Remove that cover and you will see about 45 or 50 fuses. On the top row there is 8 fuses1-60 amp 3-50 amp 2-40 amp and 2-30 amp,One of those fuses has blown most likely the 50 amp one.You have to check these fuses by removing them one at a time and looking at them.If these fuses are good then the short is still active and keeping one of the relays open.look for the short at the wires below the emergancy brake,going up thru the dashboard Do you know when this problem started did you step on the emergancy brake real hard and it started the problem Try to remember how it started did you install any new components,look for the short there.Let me know how you make out
Mike
Posted at Fri Oct 24, 2008 3:57 am
Hi
I forgot to mention that if you check the fuses and they are all good. Then all indications point to the alternator not charging. Make absolutely sure the alternating is charging.if it isnt then that is your problem Replace the alternator.
Mike
Posted at Fri Oct 24, 2008 10:07 am
i double check the fuses in the engine compartment and i found that a 50 amp fuse was blown. and i found the wire that blew the fuse under the dash thanks alot
Posted at Sat Oct 25, 2008 3:12 am
Im very glad that you found your problem and fixed it.Thanks for letting me know,it also makes me feel good that i helped you. PLAY IT FOWARD
Mike
Posted at Sat Nov 08, 2008 6:29 am
Just for my couriosity
Where was the short
Mike
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
