Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1998 Nissan Maxima My Ca...
Auto Repair1996 Dodge Ram Valve Tra...
Auto Repair1991 Bmw 320 Front Brakes
Auto Repair1998 Nissan Maxima Car S...
Auto Repair1997 Dodge Avenger Timin...
Auto Repair1997 Nissan Maxima Oil P...
Auto Repair2005 Nissan Maxima Won't...
Auto Repair1995 Nissan Maxima Hard ...
Auto Repair1996 Nissan Maxima
Auto Repair2001 Nissan Maxima Car S...
Auto Repair1990 Honda Civic Heat Gauge
Auto Repair2005 Volkswagen Jetta Gl...
Auto Repair2001 Volkswagen Jetta Al...
Auto Repair2002 Volkswagen Eurovan ...
Auto Repair1995 Volkswagen Eurovan
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 Chevy Malibu anti-theft system
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Mar 24, 2008 1:27 pm
By mkbatley, Likes cars!
Give Feedback | Votes: 0
Electrical problem
2002 Chevy Malibu 6 cyl Front Wheel Drive Automatic 78000 miles
Can't start my 2002 malibu!! The car just clicks once then nothing. All the gauges work and the battery is good. The anti-theft light stays on and when i contacted the dealership to see if they could tell me how i could fix it, they just told me to bring it in. I read about the 10 min method but found that it did not work for me. I need HELP. Ireally need my car to work and this is such an inconvenience. Anybody with any advice please respond. And yes, this is my first time here. Thank you!!
Find a repair manual for your Chevy Malibu Repair Question.
By Advertisment,
Posted at Mon Mar 24, 2008 4:05 pm
By BMRFIXIT, Tech level 10
Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6Reputation: 310.6 (311) Give Feedback | Votes: 12
try to start then leave key on security light blinks for about ten min or until light stop blinking
key off then try to start if the security light blinking
and no start you may need to do it again two more times
total of 30 minutes
also you may want to check the starter too
Posted at Tue Mar 25, 2008 9:50 am
thanks i'll try that. The starter is good I had it tested. And if that still doesn't work do I have to take it to the dealership? I am willing to try anything to not have to take it to the dealer. I think this is a total rip off. I JUST WANT TO GET IT STARTED!!!
Posted at Thu Apr 10, 2008 12:20 pm
I finally got it fixed without taking it to the dealership. A friend told me to leave the key in the ignition on the on position till THE SECURITY LIGHT GOES OFF!!! I did this and i left the key in for about 3 hours. I was able to jumpstart but ended up having to buy a new battery because the battery would not hold a charge.
Posted at Sat May 10, 2008 4:02 pm
By Nailer, Likes cars!
(10) Give Feedback | Votes: 0
The problem will return. This is a problem with GM cars built after 1998. The issue is the ignition switch. It senses the key in the ignition. If anything else is used to try to start the car it turns off the fuel to the engine. Gm is aware of the problem but has refused to address it.
A very common issue. The switch wears out and activates the anti theft. Leaving the switch on for 10 minutes or until the light goes out will reset it. Once the problem occurs you can expect it to happen again. Then more fequently. The only way to fix it right is to replace the ignition switch.( part is over $100) When you get tired of the 10 minute delay you can spend the money. There is a way to bypass the anti-theft but it is best left to an alarm specalist.
Other option is to install remote start system.
Posted at Mon May 12, 2008 5:23 am
By rhall77, Tech level 6
Reputation: 92.3Reputation: 92.3Reputation: 92.3Reputation: 92.3Reputation: 92.3 (92) Give Feedback | Votes: 3
its called a pass lock sensor. that is the part that goes bad. I would not suggest bypassing the system
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
