Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
2002 Chevy Astro 6 cyl Two Wheel Drive Automatic
The fan is blowing but there is no air coming out of the ac duct it is all coming out @ the feet. Is there a fuse or a hose off somewhere that can be causing the problem. Thanks.
I just had the same issue on a 2000. Found the small plastic vacuum hose (1/8" od) from the right side (from the front) intake manifold to the left side AC area broken. Replaced the hose and contol now works the vents.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
