Thanks. I would not have guessed it being there.
| Buzzsaw wrote: |
| blackdogdo wrote: | Located in the climate control panel | Buzzsaw wrote: | | blackdogdo wrote: | Electrical problem
2002 Cadillac Deville V8 Front Wheel Drive Automatic 115500 miles
I recently changed the battery in my 02 deville. Just trying to avoid problems. I did it the correct way + off last on 1st. Since I swapped battery my outside thermometer is way off. not c-f. Just not accurate. What can I do to fix? |
is this the thermometer in the rear view mirror? or in the IP |
ok I just needed to rember where it was you can replace the sensor its in front of the radiator and condensor, you can see it when you take off the radiator plastic cover |
