Electrical problem
2002 BMW X5 6 cyl All Wheel Drive Automatic 120000 miles
My lowbeam lights will not come on. Intermitantly, they with come on for a few seconds and then go off with a "message"...check lowbeam lights. The bulbs are good. The switch is good. It could be a bad relay??? I can't find the relay! to check it. I have the "auto-on" switch on the dash. The lights will not come on in manual or auto. Hi-beams are ok. Fog lights ok. Problem occured after about two weeks of not driving and the bat ran down. Recharged fine...but lowbeam headlights would not work. Thanks
Find a
repair manual for your BMW X5 Repair Question.
Posted at Sat Dec 29, 2007 9:10 am
By
Advertisment,
Find a
Prepare for some bad news. Try this first, disconnect the battery for a minute and then reconnect it. This is what BMW calls a master battery reset, its like control, alt, delete on your computer. If that does nothing, you will need to scan for fault codes and/or "reflash" the general module. You may have fried something during the battery recharging session.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
