Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Chrysler Town And C...
Auto Repair2002 Oldsmobile Aurora ...
Auto Repair1997 Toyota Tacoma Engi...
Auto Repair1985 Chevy S-10 Break L...
Auto Repair2003 Gmc Sierra Reduced...
Auto Repair1987 Ford F150 Ignition...
Auto Repair1994 Jeep Cherokee Alar...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2002 BMW 525 Smoking Engine
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Jul 25, 2008 4:55 am
By Corkey, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
2002 BMW 525 6 cyl Two Wheel Drive Automatic 97000 miles
I just recently had the Oil changed, after about a week I was at a stop light the light changed to green, as I accelerated a big puff of white blue smoke came out of the exaust. I took it to my Local Mechanic and had it looked at. They said they could not find anything wrong. It is still smoking badly, and I don't want to drive it until I find out what the problem is, I would like to know what a ring and Valve job will cost.
Find a car repair manual for your BMW 525 Repair Question.
Posted at Fri Jul 25, 2008 5:15 am
By Docfixit, Moderator
Reputation: 142Reputation: 142Reputation: 142Reputation: 142Reputation: 142Reputation: 142Reputation: 142 (142) Give Feedback | Votes: 5
How is it driving same pickup good idle start good?
A well maintained BMW with 97K should not be needing such expensive work. Check all fluids are they at correct levels?
Let us know
Posted at Fri Jul 25, 2008 7:10 am
The car does not smoke all the time at start up, but sometime it will. It idles good and even runs good. I checked the oil level and also to see if I could see any water in same, all were fine, also it seems not to smoke at constant speed only at acceleration or like I said sometimes at startup. Does this car have vacum assist shift? I have heard rumors that maybe this could be a problem, sucking transmission fluid back.
Posted at Fri Jul 25, 2008 7:16 am
Possible valve guide seals but you say it started after oil change. Do you go to same place every change? What weight oil did they use? Also have the PCV checked this can suck oil into engine.
Posted at Fri Jul 25, 2008 7:21 am
I have taken my car to a BMW dealer for all oil changes, they use Synthetic oil. I have thought of the pvc valve, but the shop I took it to locally said they checked that, I live 80 mi from nearest BMW dealer and was afraid to drive it there to have it checked.
Posted at Fri Jul 25, 2008 7:31 am
We have a moderator Dr. Hagarty is the premier BMW Tech. He gets on line later in day will ask him to take on your problem.
Posted at Fri Jul 25, 2008 7:41 am
Thanks, tell the Dr. when It smokes, i'm talking like a fogger spraying for mosquitos. Also I have heard of a bypass valve that is common for these to go bad, and cause this problem.
Posted at Fri Jul 25, 2008 8:21 pm
By Dr. Hagerty, Moderator
Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9Reputation: 406.9 (407) Give Feedback | Votes: 9
The smoke could well be caused by a failed cyclone separator, or as BMW calls it a "pressure regulator". The part number is 11-61-7-501-566. One additional symptom that happens is a "honking" noise from the engine, especially on deceleration or when you rev the engine slightly. This diagram may also be of help.
Posted at Sat Jul 26, 2008 5:19 am
Thanks, I think you are on the right track. I talked to a small Auto repair place here that deals with German made cars. He also said the same thing, that is a very common problem with BMW's. He called it a exhaust relieve valve, don't know if it is the same thing.
Posted at Sat Jul 26, 2008 6:20 am
It is fairly common for this failure and they can call it anything, a picture is worth a thousand ...........
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
